Как да променя WAN порта на RouterBoard 951Ui-2HnD?
panko
имам рутер MikroTik RouterBOARD 951Ui-2HnD.
Удари го гръмотевица и му изгоря WAN прота(Port #1 - PoE in) и порт №2 свети постоянно, но се линква през него даже си взима от друг рутер IP и тръгва нета.
Въпроса ми е как да променя WAN порта от №1 да стане примерно на №4.
Ако някой може да обясни нагледно стъпка по стъпка, ще съм много благодарен.
Ето експорт файла, който извадих с команда /export:
[admin@MikroTik] > /export
# jan/02/1970 00:10:11 by RouterOS 6.0rc13
# software id = W8EQ-4FH7
/interface bridge
add admin-mac=00:0C:42:C4:0E:0B auto-mac=no l2mtu=1598 name=bridge-local protocol-mode=rstp
/interface ethernet
set 0 name=ether1-gateway
set 1 name=ether2-master-local
set 2 master-port=ether2-master-local name=ether3-slave-local
set 3 master-port=ether2-master-local name=ether4-slave-local
set 4 master-port=ether2-master-local name=ether5-slave-local
/interface wireless
set 0 band=2ghz-b/g/n channel-width=20/40mhz-ht-above disabled=no distance=indoors ht-rxchains=0,1 ht-txchains=0,1 l2mtu=2290 mode=ap-bridge
/ip neighbor discovery
set ether1-gateway discover=no
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m
/ip pool
add name=default-dhcp ranges=192.168.88.10-192.168.88.254
/ip dhcp-server
add address-pool=default-dhcp disabled=no interface=bridge-local name=default
/interface bridge port
add bridge=bridge-local interface=ether2-master-local
add bridge=bridge-local interface=wlan1
/ip address
add address=192.168.88.1/24 comment="default configuration" interface=bridge-local network=192.168.88.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid disabled=no interface=ether1-gateway
/ip dhcp-server network
add address=192.168.88.0/24 comment="default configuration" dns-server=192.168.88.1 gateway=192.168.88.1
/ip dns
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router
/ip firewall filter
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=established
add chain=input comment="default configuration" connection-state=related
add action=drop chain=input comment="default configuration" in-interface=ether1-gateway
/ip firewall nat
add action=masquerade chain=srcnat comment="default configuration" out-interface=ether1-gateway
/system leds
set 0 interface=wlan1
/tool mac-server
add disabled=no interface=ether2-master-local
add disabled=no interface=ether3-slave-local
add disabled=no interface=ether4-slave-local
add disabled=no interface=ether5-slave-local
add disabled=no interface=wlan1
add disabled=no interface=bridge-local
/tool mac-server mac-winbox
set [ find default=yes ] disabled=yes
add interface=ether2-master-local
add interface=ether3-slave-local
add interface=ether4-slave-local
add interface=ether5-slave-local
add interface=wlan1
add interface=bridge-local
махни порт 4 от суича като премахнеш мастер порта
в dhcp-client задай новия интерфейс
в ip firewall nat задай новия интерфейс
обнови си версията на софтуера
в твоя случай ръчно че си с бета версията
Възможно ли е да обясниш като на малоумник?
През WinBox-a, от категория Swtich, не мога да премахна нищо.
В категория Interface, преименувах Мастера на slave-local, както са другите защото не ми позволи да го Премахна.
А в категория IP, подкатегория Firewall - таб NAT, там не мога да разбера нищо кое как да настроя.
Ако може някак си малко по опростено да ми го обясните, защото изчетох доста теми в на микротик форума, както и прегледах гугъл, както и прерових цялото wiki на микротик и няма показно как да направя LAN port на WAN port.
Благодаря Ви предварително.
Прати някакви данни за достъп и ще ти запиша видео ;)
