Продавам гигабитов, 24-порта, NORTEL Ethernet Routing Switch 4524GT
Продавам гигабитов, 24-порта, NORTEL Ethernet Routing Switch 4524GT, с планки за монтаж в 19" шкаф.
Всички RJ45-портове и SFP-слотове са тествани и нямат проблеми.
NORTEL_4524_GT_web_00.png NORTEL_4524_GT_web_01.png NORTEL_4524_GT_web_02.png
Конзола:
Booting...
Testing main memory         - PASSED
Starting...
Boot Version 5.1.0.1 Fri Apr 20 13:52:21 2007
Hardware Rev: 02
Resets: 18
Initializing Flash...
Reading MAC Address...
MAC Address: 00-21-62-13-34-00
Initializing Switch CBs...
Attaching SOC unit 0... PCI device ASIC1 attached as unit 0...
Diagnostic Version 5.1.0.7 Fri Oct 05 10:37:44 2007
Press Control-C to Enter Diag
Test ROM Config                   - PASSED
Test FANs                         - PASSED
Test Internal Loopback            - PASSED
Test ASIC1 Registers              - PASSED
Test PHY Registers                - PASSED
Test USB Registers                - PASSED
Starting Agent Code...
Decompressing the image  done.
Initializing ......
Broadcom Command Monitor: Copyright (c) 1998-2005 Broadcom Corporation
Completing initialization...
Enter Ctrl-Y to begin.
  *** Ethernet Routing Switch 4524GT                          ***
  *** Nortel                                                  ***
  *** Copyright (c) 1996-2007,  All Rights Reserved           ***
  *** HW:02       FW:5.1.0.7   SW:v5.1.0.000                  ***
4524GT>show tech
*****MEMORY INFORMATION*****
  status       bytes       blocks    avg block  max block
current
 free           75476528          5   15095305   75470472
 alloc          31796000      11625       2735          -
 internal            616          3        205          -
cumulative
 alloc          37133176      15614       2378          -
peak
 alloc          31816808          -          -          -
*****IP Configuration*****
Bootp Mode: BootP When Needed
                     Configured        In Use        Last BootP
Stack IP Address:  0.0.0.0                         0.0.0.0
Switch IP Address: 0.0.0.0         192.168.12.64   192.168.12.64
Subnet Mask:       0.0.0.0         255.255.255.0   255.255.255.0
Default Gateway:   0.0.0.0         192.168.12.2    192.168.12.2
*****Port Interface*****
              Status                     Auto                      Flow
Port Trunk Admin   Oper  Link LinkTrap Negotiation Speed    Duplex Control
1          Enable  Down  Down Enabled  Enabled
2          Enable  Up    Up   Enabled  Enabled     1000Mbps Full   Symm
3          Enable  Down  Down Enabled  Enabled
4          Enable  Down  Down Enabled  Enabled
5          Enable  Up    Up   Enabled  Enabled     1000Mbps Full   Symm
6          Enable  Down  Down Enabled  Enabled
7          Enable  Down  Down Enabled  Enabled
8          Enable  Down  Down Enabled  Enabled
9          Enable  Down  Down Enabled  Enabled
10         Enable  Down  Down Enabled  Enabled
11         Enable  Down  Down Enabled  Enabled
12         Enable  Down  Down Enabled  Enabled
13         Enable  Down  Down Enabled  Enabled
14         Enable  Down  Down Enabled  Enabled
15         Enable  Down  Down Enabled  Enabled
16         Enable  Down  Down Enabled  Enabled
17         Enable  Down  Down Enabled  Enabled
18         Enable  Down  Down Enabled  Enabled
19         Enable  Down  Down Enabled  Enabled
20         Enable  Down  Down Enabled  Enabled
21         Enable  Down  Down Enabled  Enabled
22         Enable  Down  Down Enabled  Enabled
23         Enable  Down  Down Enabled  Enabled
24         Enable  Down  Down Enabled  Enabled
4524GT>
Намира се в Пловдив.
тел.: 0885 199 229
Цена: 140 130 120 лв.
Продаден.
Редактирано от plameni
