Stoiko Публикувано 30 Юли, 2009 Доклад Сподели Публикувано 30 Юли, 2009 Поръчах си едни 8 портови суйчове, който уж трябваха да са с RTL8309SC чип, но след като демонтирах едно радиаторче се оказа че са с IC+ IP178D чип. На времето съм ползвал 5-портови суйчове с IC+ чипсет и не бях много очарован. Някой има ли преки наблюдения от суйчове с този чип на IC+ ? Не знам дали да си ги задържа или да ходя да ги връщам, че не са малко бройки. Ето какво изкарах като характеристики на двата чипа: http://www.icplus.com.tw/pp-IP178D.html IP178D 8Port 10/100 Ethernet Integrated Switch (Port Mirror, TCP/UDP QoS & VIP Port QoS) Feature : IP 178C pin to pin compatible Support 2k MAC address Support auto-polarity for 10 Mbps Support filter/forward special DA option Support broadcast storm protection Auto MDI-MDIX option Two queues per port for QoS purposes Support Port based QoS Support 802.1p & DiffServ based QoS QoS - Port base - 802.1p - IP DiffServ IPV4/IPV6 - TCP/UDP port number - Pins configure ports priority (VIP port) Support max forwarding packet length 1552/1536 bytes option Support port mirror function Support two dynamic fiber ports for Hot Plug Built in linear regulator control circuit Support Lead Free package (Please refer to the Order Information ) 0.16um Process ---------------------------------------------------- http://www.realtek.com.tw/products/productsView.aspx?Langid=1&PNid=20&PFid=21&Level=5&Conn=4&ProdID=195 RTL8309SC Single-Chip 9-Port 10/100Mbps Switch Controller Features Integrates eight 10/100 transceivers and nine MAC units for 10Base-T and 100Base-TX Embedded SRAM for packet storage On-chip 1024-entry look-up table in direct mapping mode Embedded 16-entry CAM for hash collision mapping Provides read/write access to look-up table entries via SMI interface Provides non-blocking wire speed reception and transmission Flow control fully supported: Half-duplex: backpressure flow control Full-duplex: IEEE 802.3x flow control Support for 4 LEDs per-port in various combinations for comprehensive applications Optional loop detection function with an LED to indicate the existence of a loop LEDs blink upon reset for LED diagnostics Flexible system configuration by strapping pins, EEPROM, or SMI interface Optional crossover detection and auto correction for plug-and-play Fully compliant with IEEE 802.3/802.3u. Optional Forwarding/Filtering reserved control frames (DID= 0180C2000003~0180C200000F) Optional Broadcast Input/Output Drop flow control Optional maximum packet length 1536/1552 Bytes Supports two Power Reduction methods: Power saving mode (automatic cable detection). Power down mode (via PHY register 0.11) Supports QoS function: QoS based on: (1) Port-based priority (2) 802.1p VLAN tag (3) DiffServ/TOS field in TCP/IP header (4) IP address Supports two-level priority queues with various weighting ratios Queue service rate based on weighted round robin algorithm Optional auto turn off Flow Control for 1~2 sec to avoid head-of-line blocking Supports MII interface connection to external MAC or PHY via 3 modes: PHY mode MII for router applications PHY mode SNI for router applications MAC mode MII for HomePNA or other PHY applications Flexible 802.1Q port/tag-based VLAN. Optional 802.1Q tag-VID aware function Optional VLAN Ingress Tag Admit Control Optional VLAN Ingress Member set filtering Optional ARP VLAN for broadcast packet Optional Leaky VLAN for unicast packet Optional 802.1P/Q tag insertion or removal on per-port basis (egress) 25MHz crystal input 0.18µm, CMOS technology 128-pin PQFP package 1.8V core voltage Independent power options for 2.5V or 3.3V MII interface ---------------------------------------------------------------------------- На първо четене се вижда, че IC-то е с 2к MAC талица срешу 1к за Realtek-a. www.ev-bg.com Адрес на коментара Сподели в други сайтове More sharing options...
stormmaker Отговорено 31 Юли, 2009 Доклад Сподели Отговорено 31 Юли, 2009 На времето, когато си мислех, че ще купя 2000бр и ще стана богат, братята китайци ме питаха - ртл за 1.2$ или иц+ за 2.2$ Имаше и богат избор - адмтек, кендин(много скъп), блабла, блабла2 и блабал3 Мен мама ме е учила като ходя в руската книжарница, винаги да взимам списанието от 6, вместо от 2 копейки...щото така било редно :) Адрес на коментара Сподели в други сайтове More sharing options...
NetworkPro Отговорено 31 Юли, 2009 Доклад Сподели Отговорено 31 Юли, 2009 Това че на тия линкове пише разни поддръжки не означава че те са реалзирани в крайния продукт както 99.99% от евтиниите суичове идват без нищо - цъкаш кабела и гаааз, за Разлика от Нашенските Родни НЕОМОНТАНА където функциите са реализирани! http://lan.neomontana-bg.com/ Стискам им ръцете! Евала! Следователно ще трябв да сравниш спецификациите на крайния продукт - самия суич, а не на чипа. Мамка му писна ми от 100Mbit евтинии! Време е за 1000Mbit евтиниите вече !!! - Адрес на коментара Сподели в други сайтове More sharing options...
Stoiko Отговорено 31 Юли, 2009 Автор Доклад Сподели Отговорено 31 Юли, 2009 Тея от IC+ са много тъпи ! Никаде в сайта нямат datasheet за този чип, както и за по-новите си продукти (2007-ма). Драснах им една поща да ми прятят малко инфо, но те пък започнаха да ме разпитвах за какво ми е , от коя фирма съм и т.н. Така и не ми го пратиха. Realtek-ите всичко си дават в сайта и то с големи подробности.... Китайска му работа ! www.ev-bg.com Адрес на коментара Сподели в други сайтове More sharing options...
Semoff Отговорено 4 Август, 2009 Доклад Сподели Отговорено 4 Август, 2009 Аз лично с IC+ имах доста проблеми и от както минат на RLT забравих грижите IC+ постоянно претопляха, при натоварване над 40-50 Мбит почваха да дропят пакети, някои сами се рестартираха ... ако се замисля ще се сетя още поне две - три техни магарии. Адрес на коментара Сподели в други сайтове More sharing options...
Администратор Велин Отговорено 5 Август, 2009 Администратор Доклад Сподели Отговорено 5 Август, 2009 Тея от IC+ са много тъпи ! Никаде в сайта нямат datasheet за този чип, както и за по-новите си продукти (2007-ма). Драснах им една поща да ми прятят малко инфо, но те пък започнаха да ме разпитвах за какво ми е , от коя фирма съм и т.н. Така и не ми го пратиха. Realtek-ите всичко си дават в сайта и то с големи подробности.... Китайска му работа ! точно D серията на чипа май я няма иначе за С тук Не отговарям на постове написани с шльокавица! Адрес на коментара Сподели в други сайтове More sharing options...
Stoiko Отговорено 5 Август, 2009 Автор Доклад Сподели Отговорено 5 Август, 2009 Аз лично с IC+ имах доста проблеми и от както минат на RLT забравих грижите IC+ постоянно претопляха, при натоварване над 40-50 Мбит почваха да дропят пакети, някои сами се рестартираха ... ако се замисля ще се сетя още поне две - три техни магарии. За коя серия става въпрос... C или D ? Има голяма разлика. www.ev-bg.com Адрес на коментара Сподели в други сайтове More sharing options...
