Продавам Netgear GSM7324 - гигабитов, управляем, Layer 3, суич
plameni
Продавам  Netgear GSM7324 - гигабитов, управляем, Layer 3, суич .
Всички портове, включително и SFP-слотовете са тествани и нямат проблеми.
Конзола:
NetGear Boot code......
Flash size = 16MB
Testing 128MB SDRAM..............................Pass
Select an option. If no selection in 10 seconds then
operational code will start.
1 - Start operational code.
2 - Start Boot Menu.
Select (1, 2):
Operational Code Date: Mon Jul  2 15:38:47 2007
Uncompressing.....
                       50%                     100%
Attaching interface lo0...done
Adding 37122 symbols for standalone.
Timebase: 33.000000 MHz, MEM: 132.000000 MHz, PCI: 66.000000 MHz, CPU: 264.000000 MHz
(Unit 1)>
User:admin
Password:
(GSM7324) >show hardware
Switch: 1
System Description............................. GSM7324 L3 Managed Gigabit
                                                Switch
Machine Model.................................. GSM7324
Serial Number.................................. 1mt1775m0002a
Burned In MAC Address.......................... 00:18:4D:DF:64:20
Software Version............................... 6.2.0.14
Bootcode Version............................... 02
Current Time................................... DEC 23 13:07:00 2013 UTC
Current SNTP Sync Status....................... Success
(GSM7324) >
Намира се в Пловдив.
тел.: 0885 199 229
Цена: 170 160 лв.
Заявен.
Редактирано от plameni
Продаден.
