biostar1@abv.bg Публикувано 17 Септември, 2013 Доклад Сподели Публикувано 17 Септември, 2013 (Редактирано) Conserve valuable PCI slot space in servers, eliminate server bottlenecks and migrate existing Category-5 networks to Gigabit Ethernet easily and cost-effectively with the Intel PRO/1000 MT Dual Port Server Adapter. Featuring flexible, auto-negotiating 10/100/1000 Mbps performance, the Intel PRO/1000 MT Dual Port Server Adapter is designed to automatically scale with growing networks. Enhance server performance further by teaming the two connections together or team with other Intel PRO Server Adapters using Intel’s advanced server feature software to achieve multi-Gigabit scalability and redundant failover capability. A compact form factor and swappable low-profile bracket allow this dual port Gigabit adapter to fit in even high-density, rack-mounted 1U and 2U servers. With a flexible design that fits almost any type of PCI bus, the standards-based management features and wide network operating system support help to ensure extensive compatibility with the latest server and networking environments. Цена : 150 Лв 0882208999 Картата е чисто нова и не е слагана.Остатъчна гаранция 10 месеца Редактирано 16 Септември, 2013 от biostar1@abv.bg Адрес на коментара Сподели в други сайтове More sharing options...
