Продавам управляем Layer 2+ Switch Allied Telesis AT-8550/SP
plameni
- 48 x 10/100 ports
- 2 x combo SFP - 10/100/1000(RJ-45) ports
Serial port connected at 9600 bps baud rate
Boot Loader (ROM) information:
Product Name: ATS62_LOADER
Product Version: v1.2.0
Build Date: Nov 14 2005
Build Time: 15:56:24
Press <CTRL>B key to go to Boot prompt... 0
Decompressing the Application Image, please wait................................
Decompressed 1890196 bytes from Flash to 6573216 bytes into RAM
First Memory Address ................................ 0x006a9904
Initializing Serial Communication ................... done!
Initializing Event Log .............................. done!
Initializing Console ................................ done!
Initializing I2C .................................... done!
Initializing Board .................................. done!
Initializing Flash .................................. done!
Initializing File System ............................ done!
Initializing DBLIB .................................. done!
Initializing CLI .................................... done!
Initializing Configuration .......................... done!
Initializing Authentication ......................... done!
Initializing Monitor ................................ done!
Initializing System ................................. done!
Initializing GARP ................................... done!
Initializing Drivers ................................ done!
Initializing Filter ................................. done!
Initializing Port ................................... done!
Initializing Classifier ............................. done!
Initializing ACL .................................... done!
Initializing QoS .................................... done!
Initializing Port Trunking .......................... done!
Initializing VLAN ................................... done!
Initializing Port Mirroring ......................... done!
Initializing Port Statistics ........................ done!
Initializing NetDriver .............................. done!
Initializing GARP Post Init Task .................... done!
Initializing Lacp Task .............................. done!
Initializing STP .................................... done!
Initializing SPANNING TREE .......................... done!
Initializing Port Security .......................... done!
Initializing Port Cable Test ........................ done!
Initializing SNMP ................................... done!
Initializing TCPIP .................................. done!
Initializing DHCP ................................... done!
Initializing SSL .................................... done!
Initializing ENCO ................................... done!
Initializing PKI .................................... done!
Initializing Telnet ................................. done!
Initializing IGMPSnoop .............................. done!
Initializing DoS .................................... done!
Initializing MGMT ACL ............................... done!
Initializing Enhanced Stacking ...................... done!
Initializing SNTP ................................... done!
Initializing Port Access ............................ done!
Initializing PAAcctRcv .............................. done!
Initializing SSH .................................... done!
Initializing Web Server ............................. done!
Loading configuration file "boot.cfg"
Please wait .........................................done!
Init Done !
User Access Verification - Local:
Login: manager
Password: ******
Allied Telesyn Ethernet Switch AT-8550SP - ATS62 v1.4.0
<No System Name>
Намира се в Пловдив.
тел. 0885 199 229
Цена: 85 80 лв.
EDIT
Запазен.
Продаден.
Редактирано от plameni
