UPS GUARDIAN LCD 2000AP 2000VA/AVR
Продукта е на 5 месеца. Държи без проблем по няколко машини(2-3) с по 400-500 W захранване за 30-60 минути.
INFORM GUARDIAN LCD 2000AP • InputCapacity (VA) 2000Voltage 220V or 230VInput Voltage Range -25%, +30%Frequency 50 or 60 Hz (auto sensing)• OutputPower Factor 0.6Voltage (On battery) 220V or 230V ±10%Waveform (On battery) Simulated SinewaveFrequency (On battery) 50 or 60 Hz ±1HzVoltage Regulation (AVR) AVR automatically increases output voltage 15% above input voltage if -10% to -26% of nominal AVR automatically decreases output voltage 15% below input voltage if +10% to +22% of nominal Transfer Time 2 - 6 ms.Outlets 2pcs Schuko 2pcs IEC• BatteryType Maintanence - Free lead acid batteriesRecharge Time 6 hours (to 90% of full capacity)Voltage 24 VDC Back up time 5-30 minutes (depending on computer load)• Display LCD Display (for Guardian LCD) Input&Output voltage values, AC mode/Load Level/Battery Capacity Indicators • ProtectionShort Circuit, Overload, Battery Discharge, Overcharge, Tel/Phone line (AP Models only)• CommunicationUSB port (only AP models)• Auidible alarmsBattery Mode (every 10 seconds)Low Battery (every second)Overload (every 0.5 second) Battery Replacement (every 2 seconds)Fault (Continous) • EnvironmentOperating Temp. 0-40 °CHumidity 0 to 90% non-condensingAudible Noise <40dBA Protection Class IP20• PhysicalNet Weight(kg) 11,5 Dimensions (mm) DxWxH (mm) 146 x 397 x 205• StandardsEN 62040-1-1 (safety), EN 62040-2 (EMC) • Warranty 24 months for product12 months for batteries
Цена: 150 лв
продадено
post-2888-0-32552800-1377810473_thumb.jp
post-2888-0-76601100-1377810479_thumb.jp
post-2888-0-50604000-1377810490_thumb.jp
