dombo Публикувано 18 Април, 2013 Доклад Сподели Публикувано 18 Април, 2013 (Редактирано) Продавам Draytek 2910 Изключително надежден и приятен рутер. Вижте характеристиките по-долу. Рутерът се намира в Сф, нов отворен е само да тества и да му се ъпдейтне firmware. Цена за комплекта 100лв. Мога да го изпратя с куриер за всички извън София. Куриерът е за сметка на купувача http://www.draytek.c...hp?Id=31#PdFunc Ако някой има интерес да пише 1. Dual-WAN Outbound Policy-Based Load-Balance BoD (Bandwidth on Demand) WAN Connection Fail-over 2. WAN Protocol DHCP Client Static IP PPPoE PPTP BPA L2TP 3. Firewall CSM (Content Security Management) for IM/P2P Application Multi-NAT, DMZ Host, Port-Redirection/Open Port Policy-Based IP Packet Filter DoS/DDoS Protection IP Address Anti-Spoofing E-Mail Alert and logging via Syslog Bind IP to MAC Address 4. VPN Up to 32 VPN Tunnels Protocol: PPTP, IPSec, L2TP, L2TP over IPSec Encryption: AES, MPPE and Hardware-Based DES/3DES Authentication: MD5, SHA-1 IKE Authentication: Pre-shared Key and Digital Signature (X.509) LAN-to-LAN, Teleworker-to-LAN DHCP over IPSec NAT-Traversal (NAT-T) Dead Peer Detection (DPD) VPN Pass-Through VPN Backup 5. USB 3.5G USB Modem(3.5G only can act as WAN2) USB Printer FTP client 6. Bandwidth Management Class-based Bandwidth Guarantee by User-Defined Traffic Categories DiffServ Code Point Classifying 4-level Priority for Each Direction (Inbound/Outbound) Bandwidth Borrowed Bandwidth/Session Limitation 7. Network Management Support TR-069 Web-Based User Interface (HTTP/HTTPS) Quick Start Wizard CLI (Command Line Interface) / Telnet/SSH* Administration Access Control Configuration Backup/Restore Built-in Diagnostic Function Firmware Upgrade via TFTP/FTP Logging via Syslog SNMP Management with MIB-II 8. Content Filter URL Keyword Blocking (White list and Black list) Java Applet, Cookies, Active X, Compressed / Executable / Multimedia File Blocking Web Content Filter Time Schedule Control 9. Network Features DHCP Client/Relay/Server Dynamic DNS NTP Client Call Scheduling RADIUS Client DNS Cache/Proxy UPnP Port-Based VLAN Configurable WAN2 Routing Protocol: Static Routing RIP V2 Редактирано 18 Април, 2013 от dombo Адрес на коментара Сподели в други сайтове More sharing options...
NetworkPro Отговорено 18 Април, 2013 Доклад Сподели Отговорено 18 Април, 2013 ценичката си пропуснал https://wiki.mikrotik.com/wiki/NetworkPro_on_Quality_of_Service (archive) Адрес на коментара Сподели в други сайтове More sharing options...
dombo Отговорено 18 Април, 2013 Автор Доклад Сподели Отговорено 18 Април, 2013 ценичката си пропуснал Коригирано, вече я има 100лв Адрес на коментара Сподели в други сайтове More sharing options...
NetworkPro Отговорено 18 Април, 2013 Доклад Сподели Отговорено 18 Април, 2013 Ревю на Wi-Fi модела http://www.smallnetbuilder.com/wireless/wireless-reviews/31053-draytek-vigor-2910g-reviewed?showall=&start=4 който разбира да си прави изводите https://wiki.mikrotik.com/wiki/NetworkPro_on_Quality_of_Service (archive) Адрес на коментара Сподели в други сайтове More sharing options...
master Отговорено 18 Април, 2013 Доклад Сподели Отговорено 18 Април, 2013 Какво му е процесорчето имаш ли представа? Analog Audio™ Адрес на коментара Сподели в други сайтове More sharing options...
dombo Отговорено 19 Април, 2013 Автор Доклад Сподели Отговорено 19 Април, 2013 (Редактирано) Какво му е процесорчето имаш ли представа? Най-ми е лесно да му отвъртя винтчетата и да му направя 1 снимка на платката, но не ми се иска да го отварям. Предпочитам да не го отварям за момента. Според Google в Draytek имаме Broadcom , намерих още инфо, че в модела 2920 е Infineon Danube, така че може би е такъв Редактирано 19 Април, 2013 от dombo Адрес на коментара Сподели в други сайтове More sharing options...
NetworkPro Отговорено 19 Април, 2013 Доклад Сподели Отговорено 19 Април, 2013 (Редактирано) Подвеждаща информация в горния пост на продавача. Снимки тук: http://www.tech-caffe.com/?p=12 Редактирано 19 Април, 2013 от NetworkPro https://wiki.mikrotik.com/wiki/NetworkPro_on_Quality_of_Service (archive) Адрес на коментара Сподели в други сайтове More sharing options...
dombo Отговорено 19 Април, 2013 Автор Доклад Сподели Отговорено 19 Април, 2013 Информацията по отношение на процесора, не е подвеждаща, просто е това, което успях да намеря в нета. Щом го има на снимка, вероятно и моят процесор е Самсунг. Както казах, не съм го отварял да го снимам Адрес на коментара Сподели в други сайтове More sharing options...
