Shell Публикувано 2 Февруари, 2013 Доклад Сподели Публикувано 2 Февруари, 2013 (Редактирано) Здравей те , имам една машина slackware имам usb vimicro web camera и искам да я пусна да стреамва през web при въвеждане на dmesg usb 1-1: new full speed USB device using uhci_hcd and address 3 usb 1-1: New USB device found, idVendor=0ac8, idProduct=307b usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 usb 1-1: Product: PC Camera usb 1-1: Manufacturer: Vimicro Corp. gspca: probing 0ac8:307b zc3xx: probe 2wr ov vga 0x0000 zc3xx: probe 3wr vga 1 0x4001 zc3xx: probe 3wr vga 2 0x2030 zc3xx: sensor PO2030 rev 0x03 zc3xx: probe sensor -> 2030 zc3xx: Find Sensor PO2030 gspca: video0 createdusb 1-1: new full speed USB device using uhci_hcd and address 3 usb 1-1: New USB device found, idVendor=0ac8, idProduct=307b usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 usb 1-1: Product: PC Camera usb 1-1: Manufacturer: Vimicro Corp. gspca: probing 0ac8:307b zc3xx: probe 2wr ov vga 0x0000 zc3xx: probe 3wr vga 1 0x4001 zc3xx: probe 3wr vga 2 0x2030 zc3xx: sensor PO2030 rev 0x03 zc3xx: probe sensor -> 2030 zc3xx: Find Sensor PO2030 gspca: video0 created открива usb-to и дрвайвера , но немога да го пусна към VLC player code: vlc -vvv v4l:// :v4l-vdev="/dev/video0" :v4l-norm=1 :v4l-width=320 :v4l-height=240 :v4l-fps=15 :v4l-audio=2 --sout '#duplicate{dst="transcode{vcodec=mp4v, vb=1024, sfilter=time, soverlay}:std{access=udp, mux=ts, dst=192.168.0.4:1234}"}' RESULT: VLC media player 0.8.5 Janus starting VLC root wrapper... using UID 0 (root) *************************************** * Running VLC as root is discouraged. * *************************************** It is potentially dangerous, and might not even work properly. [00000273] skins2 interface error: Cannot open display [00000273] skins2 interface error: cannot initialize OSFactory Remote control interface initialized. Type `help' for help. [00000277] main input error: no suitable access module for `v4l2://' status change: ( new input: v4l2:// ) status change: ( audio volume: 256 ) status change: ( play state: 1 ) status change: ( stop state: 0 ) [00000267] main playlist: nothing to playvlc -vvv v4l:// :v4l-vdev="/dev/video0" :v4l-norm=1 :v4l-width=320 :v4l-height=240 :v4l-fps=15 :v4l-audio=2 --sout '#duplicate{dst="transcode{vcodec=mp4v, vb=1024, sfilter=time, soverlay}:std{access=udp, mux=ts, dst=192.168.0.4:1234}"}' RESULT: VLC media player 0.8.5 Janus starting VLC root wrapper... using UID 0 (root) *************************************** * Running VLC as root is discouraged. * *************************************** It is potentially dangerous, and might not even work properly. [00000273] skins2 interface error: Cannot open display [00000273] skins2 interface error: cannot initialize OSFactory Remote control interface initialized. Type `help' for help. [00000277] main input error: no suitable access module for `v4l2://' status change: ( new input: v4l2:// ) status change: ( audio volume: 256 ) status change: ( play state: 1 ) status change: ( stop state: 0 ) [00000267] main playlist: nothing to play Редактирано 2 Февруари, 2013 от 111111 ползвай инструментите за редакция за по нагледно форматиране Адрес на коментара Сподели в други сайтове More sharing options...
Администратор 111111 Отговорено 2 Февруари, 2013 Администратор Доклад Сподели Отговорено 2 Февруари, 2013 VLC-то ти е бая стара версия ако го пускаш от конзола какво да ти пусне да гледаш ? Харесай поста ^^^ Форумът е за взаимопомощ а не за свършване на чужда работа ɹɐǝɥ uɐɔ noʎ ǝɹoɯ ǝɥʇ 'ǝɯoɔǝq noʎ ɹǝʇǝınb ǝɥʇ Адрес на коментара Сподели в други сайтове More sharing options...
Shell Отговорено 2 Февруари, 2013 Автор Доклад Сподели Отговорено 2 Февруари, 2013 Ами на адрес http://192.168.0.4:1234 би трябвало .. , но нетрагва :С какъв друг начин има за стриимване на веб камера.. Адрес на коментара Сподели в други сайтове More sharing options...
hgd Отговорено 3 Февруари, 2013 Доклад Сподели Отговорено 3 Февруари, 2013 На 2.02.2013 г. at 21:11, Shell написа: какъв друг начин има за стриимване на веб камера.. Разгледай програмата motion - работи отлично с web камери. А относно реда на vlc-то ти - то никога няма да изведе http стрийм, докато настройваш изхода да е в udp и mux - transport stream. Адрес на коментара Сподели в други сайтове More sharing options...
borislavvg Отговорено 3 Февруари, 2013 Доклад Сподели Отговорено 3 Февруари, 2013 По скоро пускаш ВЛЦ-то като руут и затова се мръщи заради сигурноста. Пробвай същото с друг потребител от групата video. Ако неможеш да помогнеш, поне не вреди. Адрес на коментара Сподели в други сайтове More sharing options...
amateur Отговорено 3 Февруари, 2013 Доклад Сподели Отговорено 3 Февруари, 2013 zoneminder http://slackbuilds.org Всеки може да опикае стените. Ако си мъж осери тавана. Адрес на коментара Сподели в други сайтове More sharing options...
Администратор 111111 Отговорено 3 Февруари, 2013 Администратор Доклад Сподели Отговорено 3 Февруари, 2013 На 3.02.2013 г. at 18:54, amateur написа: zoneminder http://slackbuilds.org това определено работи за целта Харесай поста ^^^ Форумът е за взаимопомощ а не за свършване на чужда работа ɹɐǝɥ uɐɔ noʎ ǝɹoɯ ǝɥʇ 'ǝɯoɔǝq noʎ ɹǝʇǝınb ǝɥʇ Адрес на коментара Сподели в други сайтове More sharing options...
