Продавам 26 портов суич TrendNet и рутер Микротик
1. TRENDnet TEG-224WS 26-port 10/100/1000Mbps Web-Based Smart Switch
Features:
  • 24 x 10/100Mbps Auto-negotiation MDIX Fast Ethernet Ports
  • 2 x 10/100/1000Mbps Auto-negotiation, Auto-MDIX Gigabit Ports
  • Full/Half duplex transfer mode for each port (full duplex mode only for Gigabit)
  • Store and Forward switching method
  • Integrated address Look-Up Engine with 6K absolute MAC address table
  • Supports 4MB RAM Data Buffering
  • Extensive diagnostic LED’s on the front panel
  • IEEE 802.3x flow control for Full Duplex mode
  • Back pressure flow control for Half Duplex mode
  • Easy configuration the device from a Web browser
  • Supports Port-Based VLAN and Port-Based IEEE 802.1p QoS
  • Supports Trunking (gigabit ports) and Port Mirroring
  • Support Port setting function allow user setting each port’s speed, duplex mode, and flow control
  • Standard 19” Rack-mount design
Спецификации:
LAN Standards: IEEE 802.3 10Base-T, IEEE 802.3u 100Base-TX, IEEE 802.3ab 1000Base-T, IEEE 802.3x Full Duplex Flow Control Network Media:
  • Ethernet: UTP/STP Cat. 3, 4, 5
  • Fast Ethernet: UTP/STP Cat. 5
  • Gigabit : UTP/STP Cat. 5, Cat 5E (Recommend)
Protocol: CSMA/CD Topology: Star LAN Port:
  • 24 x 10/100Mbps Auto Negotiation, Auto-MDIX Fast Ethernet ports,
  • 2 x 10/100/1000Mbps Auto Negotiation, Auto MDIX Gigabit ports
  • Address Table: 6K entries per device
Data RAM buffer: 4MB per device Data Transfer Rate:
  • Ethernet: 10/20Mbps – Half/Full-Duplex
  • Fast Ethernet: 100/200Mbps – Half/Full Duplex
  • Gigabit Ethernet: 2000Mbps – Half/Full Duplex
Diagnostic LEDs:
  • Per Unit: Power, System
  • Per Fast Ethernet Port: Link/ACT, 100M (port 1~24)
  • Per Gigabit Ethernet Port: Link/ACT, 1000M, 100M (port 25,26)
Power Consumption: 16 Watts. Max Power Supply:100-240V AC, 50/60Hz Internal Universal Power Supply Dimensions: 440 x 140 x 44 mm (17.32" x 5.5" x 1.73") Weight: 4.7 lb Temperature:
  • Operating: 0° ~ 40° C (32° ~ 104° F)
  • Storage: -10° ~ 70° C (14° ~ 158° F)
Humidity: 10% ~ 90% (no-condensing) Certifications: FCC Class A, CE Mark A, VCCI-A
Суича е неизползван със захранващ кабел.
Цена: 99 лв
2. RouterBOARD 750GL, 400MHz CPU, 64MB RAM, 5 Gbit LAN ports, RouterOS Level 4, Plastic case, Power adapter
Модел: RB/750GL
Производител: Mikrotik
Рутера е чисто нов с 2 години гаранция - закупен от РТС Компютърс.
Предоставям оригиналната гаранционна карта!
Цена: 69 лв
Намирам се в София. Изпращам по куриер за страната.
За контакти:
0882 433883
Skype: silvero69
email: teoatana@gmail.com
post-2175-0-81569200-1343642888_thumb.jp
post-2175-0-67923700-1343642890_thumb.jp
post-2175-0-43783900-1343642892_thumb.jp
post-2175-0-30330600-1343642894_thumb.jp
post-2175-0-92225000-1343642909_thumb.jp
