Nanostation Loco 2 debrick
ushoplias
При мен нещо не стана:
1.С сериал интерфейс прочетох от работещо Bullet5:
<00>+Ethernet eth1: MAC address 00:15:6d:d5:98:0c
IP: 0.0.0.0/255.255.255.0, Gateway: 0.0.0.0
Default server: 0.0.0.0
RedBoot(tm) bootstrap and debug environment [ROM]
Ubiquiti Networks certified release, version 0.9.00483.1103151314 - built 13:15:35, Mar 15 2011
Copyright (C) 2000, 2001, 2002, 2003, 2004 Red Hat, Inc.
Board: Ubiquiti Ubiquiti AR2313 based board (Ubiquiti AR2313 based board detected)
Arch: ar2313
RAM: 0x80000400-0x80ff0400, [0x80000400-0x80fd1400] available
Flash: 0xbe000000-0xbe3f0000, in 64 blocks of 0x00010000 bytes each
== Executing boot script in 1.000 seconds - enter ^C to abort
RedBoot> cache off
RedBoot> fis load -d -e kernel
Trying LZMA decompression...
Image loaded from 0x80010000-0x801b05dc
Entry point: 0x8015a040, address range: 0x80002000-0x80183000
RedBoot> go
[ 0.000000] CPU revision is: 0001800a
[ 0.000000] Primary instruction cache 16kB, physically tagged, 4-way, linesize 16 bytes.
[ 0.000000] Primary data cache 16kB 4-way, linesize 16 bytes.
[ 0.000000] Linux version 2.4.27-ubnt0 (buildd@builder) (gcc version 3.3.3) #4 Mon Dec 19 21:27:19 EET 2011
[ 0.000000] Determined physical RAM map:
[ 0.000000] memory: 01000000 @ 00000000 (usable)
[ 0.000000] On node 0 totalpages: 4096
[ 0.000000] zone(0): 4096 pages.
[ 0.000000] zone(1): 0 pages.
[ 0.000000] zone(2): 0 pages.
[ 0.000000] Kernel command line: console=ttyS0,9600 console=ttyS0,9600 root=/dev/mtdblock2 rootfstype=squashfs init=/linuxrc ro
[ 0.000000] Using 90.000 MHz high precision timer.
[ 0.010000] Calibrating delay loop... 179.40 BogoMIPS
[ 0.290000] Memory: 14468k/16384k available (1363k kernel code, 1916k reserved, 88k data, 68k init, 0k highmem)
[ 0.410000] Dentry cache hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.490000] Inode cache hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.570000] Mount cache hash table entries: 512 (order: 0, 4096 bytes)
[ 0.650000] Buffer cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.730000] Page-cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.810000] Checking for 'wait' instruction... available.
[ 0.880000] POSIX conformance testing by UNIFIX
[ 0.930000] Linux NET4.0 for Linux 2.4
[ 0.980000] Based upon Swansea University Computer Society NET3.039
[ 1.050000] Initializing RT netlink socket
[ 1.100000] Starting kswapd
[ 1.130000] Squashfs 2.2-r2 (released 2005/09/08) (C) 2002-2005 Phillip Lougher
[ 1.220000] pty: 256 Unix98 ptys configured
[ 1.270000] Serial driver version 5.05c (2001-07-08) with no serial options enabled
[ 1.360000] ttyS00 at 0xbc000003 (irq = 37) is a 16550A
[ 1.430000] PPP generic driver version 2.4.2
[ 1.480000] PPP Deflate Compression module registered
[ 1.540000] MPPE/MPPC encryption/compression module registered
[ 1.610000] physmap flash device: 800000 at be000000
[ 1.670000] phys_mapped_flash: Found 1 x16 devices at 0x0 in 8-bit bank
[ 1.750000] Amd/Fujitsu Extended Query Table at 0x0040
[ 1.810000] phys_mapped_flash: Swapping erase regions for broken CFI table.
[ 1.890000] number of CFI chips: 1
[ 1.940000] cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
[ 2.030000] mtd: adjusted dev mtd2 size from 61440 to 65536 bytes
[ 2.100000] 8 RedBoot partitions found on MTD device phys_mapped_flash
[ 2.180000] Creating 8 MTD partitions on "phys_mapped_flash":
[ 2.250000] 0x00000000-0x00030000 : "RedBoot"
[ 2.300000] 0x00030000-0x00100000 : "kernel"
[ 2.350000] 0x00100000-0x003c0000 : "cramfs"
[ 2.400000] 0x003c0000-0x003e0000 : "cfg"
[ 2.450000] 0x003e0000-0x003f0000 : "FIS directory"
[ 2.510000] 0x003ef000-0x003f0000 : "RedBoot config"
[ 2.570000] mtd: partition "RedBoot config" doesn't start on an erase block boundary -- force read-only
[ 2.680000] 0x003f0000-0x00400000 : "EEPROM"
[ 2.730000] 0x00030000-0x003e0000 : "Working flash"
[ 2.790000] Initializing Cryptographic API
[ 2.840000] NET4: Linux TCP/IP 1.0 for NET4.0
[ 2.890000] IP: routing cache hash table of 512 buckets, 4Kbytes
[ 2.970000] TCP: Hash tables configured (established 1024 bind 2048)
[ 3.040000] IPv4 over IPv4 tunneling driver
[ 3.090000] GRE over IPv4 tunneling driver
[ 3.140000] Linux IP multicast router 0.06 plus PIM-SM
[ 3.200000] NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
[ 3.270000] Ebtables v2.0 registered
[ 3.320000] NET4: Ethernet Bridge 008 for NET4.0
[ 3.370000] Bridge firewalling registered
[ 3.420000] 802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
[ 3.500000] All bugs added by David S. Miller <davem@redhat.com>
[ 3.580000] VFS: Mounted root (squashfs filesystem) readonly.
[ 3.650000] Freeing unused kernel memory: 68k freed
[ 3.710000] Warning: unable to open an initial console.
[ 4.060000] Algorithmics/MIPS FPU Emulator v1.5
UBNT login:
2.Flash: 0xbe000000 тоест RedBoot започва от този адрес
3.CPU Atheros AR2313A-001 MX 29lv320DTXBI-70G - това е флаша и го няма в списъка
4.От работещо Bullet5 сwrtjp.5.2 и /fc:97 изчетох всички части от флаша.
5. При
wrtjp -flash:custom /skipdetect /window:0xbe000000 /start:0xbe000000 /length:0x00030000 /fc:97
стигна до това
Total Blocks to Erase: 3
Erasing block: 1 .......
стои и не продължава
Ако използвам част от флаша където е с "FF" излиза
Erasing block: 3 (addr = bc....00)...Done
Loading CUSTOM.BIN to Flash Memory...
стои и не продължава.
Пробвал съм с 2 броя JTAG направени с 2бр. 74НС125 и другия с 74НС244 и с различни РС
Моля за някакви идеи или друг софтуер който работи с CPU Atheros AR2313A-001 и MX 29lv320DTXBI-70G
Благодаря предварително
  • 1 месец по-късно ...
Да пораздвижим темата :)
Здрaвейте, донесоха ми един Nanostation 2, минал е през 2-3ма специалиста и от задружната им работа резултата е:
- работещ зелен power led!
- при свързване с компютър няма никой!
- на serial нищо!
Проблема е, че няма от къде да копирам работещ RedBoot!
Ако някой има Nanostation 2 и му се занимава, нека копира RedBoot-а и с дружни усилия да съживим един мъртвец :D
Конзолата е:
-Nanostation 2
-Atheros AR2315A
-Памет (M) 25P32 V6P
Поздрави!
Все още търся RedBoot, ако някой има нещо да свирка!
Между другото намерих един предлаган от OpenWrt, но с него единственото което се получава е някаква връзка с компютъра (и това е нещо), нямя ping няма serial communication........
Пробвах и външно флашване на паметта с файлове свалени от руски форуми за които се казва че са от работещи устройства, но без успех!
Сега единственото което остава е копиране на работещ боотлодер от друга конзола и флаш само през Jtag, защото паметта не търпи повече сваляне, на следващото разпояване пътечките на платката най вероятно ще паднат вече и.........край!
Предлагам малко фотоси от тежкия труд :)
http://booker.snimka.bg/other/nanostation-2.645798.28493121
  • 3 weeks later...
booker, в SDK-то има едно утилче - fwsplit.
Оригинален фърм като се сплитне с това, се получаваха отделните елементи в отделни файлчета, и едното май беше боот-а.
  • 3 месеца по-късно ...
Благодаря за инфото-ushoplias
След доста опити, установих че нано-то е покойник! :ph34r:
Пробвах го с копирана Full flash от работещо устройство и нова памет, но няма признаци на живот!
Също така пробвах със същия Fullflash οτ NS2 на TL-WA5210G и се получи интересен хибрид, ТП-линка заработи с фърм-а на NS2-AirOS!
Сега да не кажеш че работи и по добре ;)
разбира се че не става
100% става , щом имам флашове с променен вутлодер по LAN от вирус значи че може и да се чете. това става през SSH.
  На 29.01.2013 г. at 10:40, 111111 написа:
Ами...не, индикатора за сигнала и хоризонталната поляризация не работят, а скоростта беше под всякаква критика!!!
А относно прочитането на флаша през SSH-защо не споделите как става тук в темата, за да бъде полезно и за останалите!
Редактирано от booker
  • 7 месеца по-късно ...
  На 30.01.2013 г. at 6:35, booker написа:
я кажи как св сържи TP-w5210  с флаш на Nanostation?
