freenet Публикувано 15 Март, 2012 Доклад Сподели Публикувано 15 Март, 2012 (Редактирано) Продавам ASUS XONAR DG, 5.1 Chanel Audio, PCI ,ползвана месец пълна окомплектовка както е купена . ЦЕНА: 50лв. Производител:Asus Тип Звукови карти:Вътрешни Начин на свързване:PCI Бр. канали:5.1 Екстри:S/PDIF Optimized for Immersive Gaming Action through Precision Audio The Xonar DG sound card combines Dolby Headphone 5.1 high definition surround with ASUS’ own GX 2.5 gaming audio engine and an on-board headset amplifier. These result in accurate and deep audio that brings every nuance and sound across fully, making the new Xonar DG an ideal sound card for gamers who want to remain totally aware of their play environments. Built-in Headphone AMP Powers up every sound detail in gaming 3 headphone Amp gain modes for different usage scenarios - VOIP mode Specialized for VOIP headsets. Providing clear communication and music enjoyment. - Pro-gaming mode Adding extra dynamics in higher frequencies for enhanced audio positioning. - Exciter mode Immerse in the game with more powerful bass punch and fuller sound field. Dolby® Headphone for an immersive 5.1 surround imaging GX2.5 for realistic 3D audio effects Automatic jack-sensing front-panel output Audio auto-switched from back to front with headphone plugged in! Audio Performance Output Signal-to-Noise Ratio (A-Weighted): 105 dB Input Signal-to-Noise Ratio (A-Weighted): 103 dB Output THD+N at 1kHz: 0.0025% (-92dB) Input THD+N at 1kHz: 0.0022% (-93dB) Frequency Response (-3dB, 24-bit/96kHz input): <10Hz to 48kHz Output/Input Full-Scale Voltage 1Vrms (3Vp-p) Bus Compatibility PCI: PCI v2.2 or above bus compatible Main Chipset Audio Processor: C-Media CMI8786 High-Definition Sound Processor (Max. 96KHz/24bit) 24-bit D-A Converter of Digital Sources: Cirrus Logic CS4245*1 (104dB DNR, Max. 192KHz/24bit) / Cirrus Logic CS4361*1 (103dB DNR, Max. 192KHz/24bit) 24-bit A-D Converter for Analog Inputs: Cirrus Logic CS4245*1 (104dB DNR, Max. 192KHz/24bit) High Fidelity Headphone Amplifier: Optimized for 32~150Ω Sample Rate and Resolution Analog Playback Sample Rate and Resolution: 44.1K/48K/96KHz @ 16/24bit for all channels Analog Recording Sample Rate and Resolution: 44.1K/48K/96KHz @ 16/24bit S/PDIF Digital Output: 44.1K/48K/96KHz @ 16/24bit, Dolby Digital, DTS, WMA-Pro ASIO 2.0 Driver Support: 44.1K/48K/96KHz @ 16/24bit I/O Ports Analog Output Jack: 3.50mm mini jack *3 (Front/Side/Center-Subwoofer) Analog Input Jack: 3.50mm mini jack *1 (Line-In/Mic-In) Other line-level analog input (for CD-IN/TV Tuner): Aux-In (4-pin header on the card) Digital S/PDIF Output: High-bandwidth Optical Connector supports 96KHz/24bit -additional SPDIF-out header for HDMI audio output Front-Panel Header: Supports headphone jack-detection, automatically switch audio output from back-panel to front Driver Features Operation System: Windows 7/Vista/XP/MCE2005 Dolby® Technologies: Dolby Headphone: technology allows users to listen to music, watch movies, or play games with the dramatic 5.1-channel surround or realistic 3D spacious effects through any set of stereo headphones. Smart Volume Normalizer™: Normalizes the volume of all audio sources into a constant level and also enhances your 3D sound listening range and advantages in gaming Xear 3D™ Virtual Speaker Shifter: Adjustable virtual 7.1-speaker positioning Magic Voice™: Changes your voice pitch to different types (Monster/Cartoon…) for disguising your real voice or just for fun in online chatting Karaoke Functions: Music Pitch-Shifting, Vocal Cancellation, and Microphone Echo effects with Stereo Mix recording (Wave and Mic-in) for online Karaoke or online DJ applications FlexBass™: Professional Bass Management/Enhancement system Other Effects: 10-band Equalier/27 Environment Effects 3D Sound Engines/APIs: 7: DirectSound3D® GX 2.5, EAX®2.0&1.0, DirectSound® HW, DirectSound SW, A3D®1.0, OpenAL generic modes, 128 3D sounds processing capability Vista: DirectSound3D® GX 2.5, EAX®2.0&1.0, DirectSound® HW, DirectSound SW, A3D®1.0, OpenAL generic modes, 128 3D sounds processing capability XP: DirectSound3D® GX 2.5, EAX®2.0&1.0, DirectSound® HW, DirectSound SW, A3D®1.0, OpenAL generic modes, 128 3D sounds processing capability DS3D GX2.5: DS3D GX 2.5 supports EAX gaming sound effects and DirectSound 3D hardware enhanced functions on Windows 7/Vista. (DirectX/DirectSound 3D compatible) VocalFX™: The latest vocal effect technologies for gaming and VoIP, including: - VoiceEX: produces vivid environmental reverberation for your voice in EAX games - ChatEX: emulates different background environment effects when you chat online - Magic Voice: changes your voice pitch to different types (Monster/Cartoon…) for disguising your real voice or just for fun in online chatting Accessories 1 x Low-profile Bracket 1 x Driver CD 1 x Quick Start Guide Size (Width x Height) 64.39 x 170.44mm ========================================================================================================= Intel 945GCLF2D +1Gb ram - 120 лв, http://ark.intel.com...GHz-533-MHz-FSB) IBM PC 300PL cpu 700MHz/256/100 128Mb ram , hard 6,4Gb , in. video sound lan,3 slot ram 3 slot pci - 50лв.(за рутер) SWX-SR5 + преходник към pci + пигтейл-mmcx-N-female - 70лв. Редактирано 25 Март, 2012 от freenet Адрес на коментара Сподели в други сайтове More sharing options...
freenet Отговорено 25 Март, 2012 Автор Доклад Сподели Отговорено 25 Март, 2012 Добавени още... Адрес на коментара Сподели в други сайтове More sharing options...
