NetworkPro Публикувано 3 Декември, 2008 Доклад Сподели Публикувано 3 Декември, 2008 /system script add name=set_pppoe_queues \ source={ :local mark-p2p p2p :local mark-non-p2p other /queue tree{ # # First remove any invalid queues. This happens whenever a pppoe # connection is dropped - even if the connection returns the queue is # forever lost. # :foreach j in [find invalid=yes] do { # # MT Bug?: "disabled" entries are considered to be "invalid" and # would be deleted here - this keeps any "disabled" entries # :if (![get $j disabled]=yes) do { remove $j } } } /interface { :foreach i in [find type="pppoe-in"] do { :set ifacename ([get $i name]) # This will print the list of interfaces found (debugging) # :put ($ifacename) :set queuename ([:pick $ifacename 1 ([:len $ifacename] - 1)]) # Print the queue name to the console (debugging) # :put $queuename /queue tree{ # # Create a "master-queue". The parent is the virtual interface # (pppoe) not the physical interface :if ([:len [find name=($queuename . " all out")]] = 0) do { add name=($queuename . " all out") parent=$ifacename \ queue=qtype_p2p priority=1 limit-at=50000 \ max-limit=400000 } # # MT Bug?: It is possible to add a sub-queue to a "disabled" parent # queue, and the sub-queue is not made "invalid" despite the fact # that the parent queue "does not exist" (ie is "invalid") # This prevents adding queue to a disabled parent :if (![get [find name=($queuename . " all out")] disabled]=yes) do { # Create a "sub-queue" for p2p traffic. The parent is the # "master-queue" for the virtual interface (pppoe) :if ([:len [find name=($queuename . " p2p out")]] = 0) do { add name=($queuename . " p2p out") \ parent=($queuename . "all out") \ packet-mark=$mark-p2p queue=qtype_p2p priority=8 \ limit-at=50000 max-limit=200000 } # Create a "sub-queue" for non-p2p traffic. The parent is the # "master-queue" for the virtual interface (pppoe) :if ([:len [find name=($queuename . " non-p2p out")]] = 0) do { add name=($queuename . " non-p2p out") \ parent=($queuename . "all out") \ packet-mark=$mark-non-p2p queue=qtype_non_p2p \ priority=1 limit-at=0 max-limit=0 } # Depending on how you have set up packet marking in mangle you # can create "sub-queues" here for any other type of traffic sent out # on this virtual interface (pppoe) } } } } } / system scheduler add name=set_pppoe_queues \ on-event=set_pppoe_queues \ interval=15s \ comment="Sets up non-simple pppoe queues for QoS" - Адрес на коментара Сподели в други сайтове More sharing options...
Администратор 111111 Отговорено 4 Декември, 2008 Администратор Доклад Сподели Отговорено 4 Декември, 2008 Това с 2.9.хх работи ли? при мен нежелае Харесай поста ^^^ Форумът е за взаимопомощ а не за свършване на чужда работа ɹɐǝɥ uɐɔ noʎ ǝɹoɯ ǝɥʇ 'ǝɯoɔǝq noʎ ɹǝʇǝınb ǝɥʇ Адрес на коментара Сподели в други сайтове More sharing options...
NetworkPro Отговорено 4 Декември, 2008 Автор Доклад Сподели Отговорено 4 Декември, 2008 Не съм тествал. Може да е за 2.8. Дава ти грешки при пействането в терминала? Или просто скрипта не изпълнява задачата си? - Адрес на коментара Сподели в други сайтове More sharing options...
Администратор 111111 Отговорено 4 Декември, 2008 Администратор Доклад Сподели Отговорено 4 Декември, 2008 просто недейства нещо орязано има или не е копиран правилно дори по скоро е непълен защото невключва маркиране Харесай поста ^^^ Форумът е за взаимопомощ а не за свършване на чужда работа ɹɐǝɥ uɐɔ noʎ ǝɹoɯ ǝɥʇ 'ǝɯoɔǝq noʎ ɹǝʇǝınb ǝɥʇ Адрес на коментара Сподели в други сайтове More sharing options...
NetworkPro Отговорено 5 Декември, 2008 Автор Доклад Сподели Отговорено 5 Декември, 2008 Преди години май от тук го сейвнах: http://www.butchevans.com/readarticle.php?article_id=15 - Адрес на коментара Сподели в други сайтове More sharing options...
