MIKROTIK НОВИ ПРОДУКТИ !!!
NetworkPro
Интересно решение от микротик със SFP:
http://www.gowifi.co.nz/specs/rb2011LS.pdf
Дано да не му горят лановете както на останалите. Като гледам има доста хляб за тунинг и явно ще поддържа и WIFI което го прави повече от супер за FTTB + HotSpot
  • 2 месеца по-късно ...
Излезнал новия бюлетин на Микротик
http://download2.mik...com/news-41.pdf
има нови интересни продукти като 4 портова гигабит карта на PCI-E
RB44GE
Нов гигабит рутер с екран и оптика
http://routerboard.com/RB2011UAS-2HnD-IN
И то не просто екран ами и touch screen :)
RB44GE
http://routerboard.c...2011UAS-2HnD-IN
  • 7 месеца по-късно ...
http://gregsowell.com/?p=4497 http://www.mikrotik..../share/hr13.pdf
  • Speed improvements
  • Simple queues now 9X faster
  • Hardware encryption, L7, PPP, and others in works
Then they talk about some SXT stuff, which is great, I love the SXTs.
These have been announced, but I haven’t talked about them sooooo:
  • Gig ports
  • 600MHz CPU
  • 128MB RAM
  • 2.5dBi antenna
This has the same form factor as the 751 routers, but has a more powerful CPU and more RAM. I’m assuming these will replace the 751s?
  • 5 gig ports
  • SFP port on back
  • SwitchOS
Blah
  • $40
I like everything about this save for SwitchOS…just not a fan.
S-85DLC05D
S-31DLC20D
  • Single Mode – $29
  • Multi Mode – $22
This is a crazy good price for new optics!
This looks AWESOME. I would say this is direct competition with the Ubiquiti Rockets. I’m willing to bet I can make a bracket that will let you mount this right on a Ubiquiti antenna icon_razz.gif
Features the new 911 inside.
  • Mini PCI E
  • 2GHz
  • 800mw
  • Mini PCI E
  • 2 and 5GHz models
  • 1000mw
This has 4 slots for the new miniPCI-E cards as well as slots for 3G cards…a lot of power in a single card.
This looks like a cool new radio for distance P2P as well as client connections.
Sector SXT.
2 or 5GHz.
  • Runs RouterOS
  • 24 Gb ports
  • SFP slot
  • Wireless version – 2Ghz
Soooo they finally put out a real switch, or is it a router? Since it runs routerOS I’m going to say it’s a router(not really, it is a switch people). Thanks to Andrew for bursting my bubble by telling me that it has a 600MHz AR9344 CPU. I think this was a brilliant move on their part, but what I’m really waiting for is the price.
I can imagine purchasing one of these to terminate A sizable chunk of P2Ps I have. Now we ask the question…will they make a version that has 12 SFPs and 12 copper or 24 SFP with 2 coppers?
Right now I’m content with just the 24 copper icon_smile.gif I also want to see a shot of the rackmount version.
  • 8 gig ports
  • 2 SFP+ ports – 10Gb interfaces
  • 16Gb RAM version
CCR1036-8G-2S+ - 10Gigabit CCR, 2x SFP+, 8x Gigabit Ethernet, 36 Core Tilera, 16GB RAM, 28Gbit throughput, 42 Million PPS, Available June
CRS - Cloud Router Switch, RouterBoard 9xx series device with 24 switched Gigabit ports (switch chip), runs RouterOS, 1x SFP. Available in IN (desktop) and RM (Rackmount) models. Also a wireless model is available. Available May
RB911G - Compact CPE/AP, Gigabit Ethernet, Metal Shielded RJ45, Integrated 2Ghz OR 5Ghz radio, 600Mhz Atheros CPU. Available April
RB912G - Compact CPE/AP, Gigabit Ethernet, Metal Shielded RJ45, Integrated 2Ghz OR 5Ghz radio, Mini PCI-e, SIM slot, 600Mhz Atheros CPU. Available April
RB912G Outdoor - The above but in a really nice outdoor case, SMA connectors soldered to board, pole or DIN rail mount. Available April
Sextant G - Sextant with RB911G inside. Available April
CCR Extended Ram - Normal CCR with more RAM (16GB).
R11E-2HND - 2Ghz Mini PCI-e, 800mw, u-fl connectors
R11E-HPND - 2Ghz or 5Ghz models, 1watt, MMCX connectors, nice big heatsink
RB14EU - PCI-e to 4x Mini PCI-e converter. Allows use of WiFi/3G cards in a x86 PC. has USB passthrough to allow 3G to work. Available June
SXTHG - High Gain SXT, 17.4dB antenna, more directional, 1 watt, Gigabit ethernet (metal shield), 5Ghz. Available May
SXTSA - Sector Antenna SXT, 90degree sector antenna in standard SXT housing. Available May
Groove52 - Dual-band Groove with new 600Mhz Atheros CPU. Available April.
Редактирано от NetworkPro
912G outdoor ше трябва да се пробва веднага, като заместител на Rocket M5 , каквато е и идеята му :)
Усещам сладкото падение на UBNT :) ОООО ДА :)
одаааааааааааааа R11E-HPND мхм това нещо май ще е с ар9580 2х2 чудно знам че ги правят 3х3
AR9283 би следвало да поддържа 25/30MHz ширина :) и вече се замислям за проба със два SEXTANT G на 5км ако не им е далечко :)
Интересно, ще им утеснее на UBNT :))
че 711 ките и SXT то са ар9283 те си ги подържат без проблем 50 и 60 мхз а за сехтанта на 5 км ми се струва малко далеко заби ги на 60 ки или 90 ки и да мъркат като коте на язовир :)
SXT- да го сложиш на паница ама SEXTANT такава сянка ще хвърли че половината усилване на антената ще отиде под дяволите
