Load balansing PCC problem
stanioomega
Мъча се да направя лоад балансинг с 2 ADSL-a
прочетох всичко исписано във wiki.mikrotik.com и като че ли този пример най ми най хареса http://wiki.mikrotik.com/wiki/Manual:PCC , но срещам малко проблем и доста неизвестни ???
Версията на Микротика е 3.30 lvl 4
/ip firewal mangle
add action=mark-connection chain=input comment=LoadBalansing_PCC disabled=no in-interface=WAN1 \
    new-connection-mark=WAN1_conn passthrough=yes
add action=mark-connection chain=input comment="" disabled=no in-interface=WAN2 new-connection-mark=\
    WAN2_conn passthrough=yes
add action=mark-routing chain=output comment="" connection-mark=WAN1_conn disabled=no \
    new-routing-mark=to_WAN1 passthrough=yes
add action=mark-routing chain=output comment="" connection-mark=WAN2_conn disabled=no \
    new-routing-mark=to_WAN2 passthrough=yes
add action=accept chain=prerouting comment="" disabled=no dst-address=192.168.2.0/24 in-interface=\
    bridge1
add action=accept chain=prerouting comment="" disabled=no dst-address=192.168.1.0/24 in-interface=\
    bridge1
add action=mark-connection chain=prerouting comment="" disabled=no dst-address-type=!local \
    in-interface=bridge1 new-connection-mark=WAN1_conn passthrough=yes per-connection-classifier=\
    both-addresses:2/0
    in-interface=bridge1 new-connection-mark=WAN2_conn passthrough=yes per-connection-classifier=\
    both-addresses:2/1
add action=mark-routing chain=prerouting comment="" connection-mark=WAN1_conn disabled=no \
    in-interface=bridge1 new-routing-mark=to_WAN1 passthrough=yes
add action=mark-routing chain=prerouting comment="" connection-mark=WAN2_conn disabled=no \
    in-interface=bridge1 new-routing-mark=to_WAN2 passthrough=yes
add action=mark-connection chain=prerouting comment="" disabled=no new-connection-mark=1st_conn \
    passthrough=yes per-connection-classifier=src-address-and-port:3/0
add action=mark-connection chain=prerouting comment="" disabled=no new-connection-mark=2nd_conn \
    passthrough=yes per-connection-classifier=src-address-and-port:3/1
add action=mark-connection chain=prerouting comment="" disabled=no new-connection-mark=3rd_conn \
    passthrough=yes per-connection-classifier=src-address-and-port:3/2
/ip route
add check-gateway=ping comment=LoadBalansing_PCC disabled=no distance=1 dst-address=0.0.0.0/0 gateway=\
    192.168.1.1 routing-mark=to_WAN2 scope=30 target-scope=10
    192.168.2.1 routing-mark=to_WAN1 scope=30 target-scope=10
add check-gateway=ping comment=¨¨ disabled=no distance=1 dst-address=0.0.0.0/0 \
    gateway=192.168.2.1,192.168.1.1 scope=30 target-scope=10
/ip firewall nat
add action=masquerade chain=srcnat comment="masquerade WAN1 network" disabled=no out-interface=WAN1
add action=masquerade chain=srcnat comment="masquerade WAN2 network" disabled=no out-interface=WAN2
/ip address
add address=10.10.10.1/24 broadcast=10.10.10.255 comment="hotspot network" disabled=no interface=\
    bridge1 network=10.10.10.0
add address=192.168.1.40/24 broadcast=192.168.1.255 comment="" disabled=no interface=WAN2 network=\
    192.168.1.0
add address=192.168.2.40/24 broadcast=192.168.2.255 comment="" disabled=no interface=WAN1 network=\
    192.168.2.0
Като цяло това нещо работи , но не съм много сигурен до колко добре ....
може ли някой занимамавал се е с това да каже дали всичко е наред , понеже виждам доста неща които не мога да си ги обесня за мен ,
например Първият проблем е , в ip firewal mangle последните 3 правила тези 1st_conn ,2st_conn  и 3st_conn не виждам да се ползват за нещо , а ако преместиа правилата на горна позициа и дори и да ги деактивирам и нета спира
после , незнам има ли начин един от АДСЛ ите да е с малко по голиам преоритет , понеже на единия нета е по слаб от дръгия,
и още един въпрос , понеже имам намерение да взема още един АДСЛ какво ше трябва да добавя за да го натикам в бозата
И изобщо това ли е най добрия вариянт за load balans  в моя случай
Еб.ш не еб.ш на .уя времето минава ...
Почвам да се вкарам вече във филми... всичко работи нормално и станели .. 19-20 часа и всичко се срива...  в случая PPPoE  към близалките се срина и край.. няма оправия въпреки че след 1мин пак се върза
Е ще ги пишем само да стигнем с четенето до скриптовете :)
и понеже не съм на ясно със скриптовете (както и с много други неща)
се пробваме с това http://wiki.mikrotik.com/index.php?title=Advanced_Routing_Failover_without_Scripting
Редактирано от AJO
