NetworkPro Публикувано 7 Януари, 2024 Доклад Сподели Публикувано 7 Януари, 2024 (Редактирано) Здравейте, Целта е да се спре tr069 ACS. Пушва се следното което спира http мениджмънт достпъпа : ation changes the ACS URL: http://10.20.254.34:37168/basic.xml, Result:Success Set,InternetGatewayDevice.X_HW_DNS:,LocalDNSPolicy:1,SupportedRecordTypes:AAAA Set,InternetGatewayDevice.X_HW_UserServiceInfo:,ServiceDescription: Set,InternetGatewayDevice.QueueManagement:,Enable:0,X_HW_ClassificationEnable:0,X_HW_Mode:OTHER Set,InternetGatewayDevice.X_HW_ALG:,FtpEnable:1,H323Enable:1,IPSecForward:1,L2TPForward:1,PptpEnable:1,RTCPEnable:1,RTCPPort:0,RTSPEnable:1,SipEnable:1,... Set,InternetGatewayDevice.X_HW_AmpInfo:,RfFilterSwitch:2,RogueOntCheckSwitch:0 Set,InternetGatewayDevice.X_HW_APMPolicy:,EnablePowerSavingMode:1 Set,InternetGatewayDevice.X_HW_Security:,X_HW_FirewallLevel:Custom,X_HW_IPv6FWDFireWallEnable:0 Set,InternetGatewayDevice.LANDevice.LANHostConfigManagement:1,X_HW_DHCPOption82Enable:0,X_HW_PPPoEPITPEnable:0 Set,InternetGatewayDevice.LANDevice.LANEthernetInterfaceConfig:1.4,X_HW_L3Enable:0 Set,InternetGatewayDevice.LANDevice.LANEthernetInterfaceConfig:1.3,X_HW_L3Enable:0 Set,InternetGatewayDevice.LANDevice.LANEthernetInterfaceConfig:1.2,X_HW_L3Enable:1 Set,InternetGatewayDevice.LANDevice.LANEthernetInterfaceConfig:1.1,X_HW_L3Enable:1 Set,InternetGatewayDevice.Services.X_HW_AccessLimit:,Mode:Off,TotalTerminalNumber:0 Set,InternetGatewayDevice.X_HW_AmpInfo.X_HW_Spec:,X_HW_EthTrapEnable:0,X_HW_HGDetectEnable:0,X_HW_HGVlan:3999 Set,InternetGatewayDevice.Services.X_HW_IPTV:,BridgeWanProxyEnable:1,GenQueryInterval:125,GenResponseTime:100,IGMPEnable:0,IGMPVersion:2,... Set,InternetGatewayDevice.X_HW_Security.FirewallLog:,FirewallLogRight:0 Set,InternetGatewayDevice.X_HW_APMPolicy.BatteryAlarmPolicy:,AlwaysEnable:1,VoiceServiceEnable:1 Set,InternetGatewayDevice.Services.X_HW_PortalManagement:,DefaultUrl:,Enable:0 Set,InternetGatewayDevice.LANDevice.X_HW_RouterAdvertisement:1,ManagedFlag:0,OtherConfigFlag:1,mode:Manual Set,InternetGatewayDevice.X_HW_Security.WANSrcWhiteList:,WANSrcWhiteListEnable:0 Set,InternetGatewayDevice.X_HW_Security.AclServices:,FTPLanEnable:0,FTPWanEnable:0,HTTPLanEnable:0,HTTPWanEnable:0,TELNETLanEnable:0,TELNETWanEnable:0 Set,X_HW_Security.AclServices.AccessControl:,AccessControlListEnable:0 Set,LANHostConfigManagement.X_HW_IPv6Interface.IPv6Address:1.1.1,IPv6Address:... Add,InternetGatewayDevice.WANDevice.WANConnectionDevice:1.2 Set,InternetGatewayDevice.WANDevice.WANConnectionDevice:1.1 Add,WANDevice.WANConnectionDevice.WANIPConnection:1.2.1,AddressingType:DHCP,ConnectionType:IP_Routed,DNSEnabled:1,DNSServers:,Enable:1,MaxMTUSize:1500,... Set,WANDevice.WANConnectionDevice.WANIPConnection:1.1.1,AddressingType:DHCP,ConnectionType:IP_Routed,DNSEnabled:1,DNSServers:,Enable:1,MaxMTUSize:1500,... Add,InternetGatewayDevice.X_HW_DNS.SearList:1,DNSServer:,DomainName:,Interface: Xml-Config,VoiceServiceConfig:- Xml-Config,BroadbandServiceConfig:- Set,InternetGatewayDevice.LANDevice:1,X_HW_WlanEnable:1 Set,InternetGatewayDevice.LANDevice.X_HW_LanService:1,HttpUnreachableRedirectEnable:0 Set,InternetGatewayDevice.Time:,DaylightSavingsUsed:0,Enable:0,LocalTimeZone:+00:00,LocalTimeZoneName:...,NTPServer1:clock.fmt.he.net,... Set,InternetGatewayDevice.Layer3Forwarding:,X_HW_AutoDefaultGatewayEnable:0,X_HW_WanDefaultWanName: Set,InternetGatewayDevice.LANDevice.X_HW_IPv6Config:1,IPv6DNSConfigType:HGWProxy,IPv6DNSServers:,IPv6DNSWANConnection: Set,LANDevice.LANHostConfigManagement.X_HW_DHCPOptionInherit:1,DHCPOptionInheritEnable:0,OptionInheritFromWAN:,OptionList:,VendorClassID:,... Set,LANHostConfigManagement.X_HW_IPv6Interface.IPv6Prefix:1.1.1,ChildPrefixMask:...,Mode:WANDelegated,ParentPrefix:,PreferredLifeTime:3600,... Set,WANConnectionDevice.WANIPConnection.X_HW_6RDTunnel:1.1.1,Enable:0,RdBRIPv4Address:,RdIPv4MaskLen:10,RdMode:Dynamic,RdPrefix:,RdPrefixLen:40 Set,WANConnectionDevice.WANIPConnection.X_HW_6RDTunnel:1.2.1,Enable:0,RdBRIPv4Address:,RdIPv4MaskLen:10,RdMode:Dynamic,RdPrefix:,RdPrefixLen:40 Set,WANIPConnection.X_HW_IPv6.DSLite:1.1.1,AFTRName:,InTunnelMTU:1460,OutTunnelMTU:1500,WorkMode:Off Set,WANIPConnection.X_HW_IPv6.DSLite:1.2.1,AFTRName:,InTunnelMTU:1460,OutTunnelMTU:1500,WorkMode:Off Add,WANIPConnection.X_HW_IPv6.IPv6Address:1.2.1.1,ChildPrefixBits:,Origin:AutoConfigured Add,WANIPConnection.X_HW_IPv6.IPv6Address:1.1.1.1,ChildPrefixBits:,Origin:AutoConfigured Add,WANIPConnection.X_HW_IPv6.IPv6Prefix:1.1.1.1,Origin:PrefixDelegation,Prefix: Add,WANIPConnection.X_HW_IPv6.IPv6Prefix:1.2.1.1,Origin:PrefixDelegation,Prefix: Set,InternetGatewayDevice.ManagementServer:,ConnectionRequestPassword:-,ConnectionRequestUsername:acs,Password:-,Username:cpe,X_HW_CheckPasswordComplex:0,... тези настройки, не помгат https://sourceforge.net/projects/echolife-ont-tools-huawei/ + https://drive.google.com/file/d/1OMJ69QPMhz2Di7igFjnkqc4dP_32XC_d/view - не е тествано Редактирано 8 Януари, 2024 от NetworkPro - Адрес на коментара Сподели в други сайтове More sharing options...
Администратор kokaracha Отговорено 8 Януари, 2024 Администратор Доклад Сподели Отговорено 8 Януари, 2024 преди WAN-а му трябва да има бридж на който да дропва / спуфва мрежата или адреса на acs-a ,или с поялника да си изкараш сериал конзола 10.20.254.34 Use since OpenBSD 3.x FreeBSD 4.x Centos 5.x Debian 3.x Ubuntu 7.x Аз съм фен на OpenWRT. Горчивината от лошото качество остава дълго след като е преминало удоволствието от ниската цена. _____________________________ ___|____|____|____|____|____|__ _|____|____|____|____|____|____ ___|____|_ Удряй _|____|____|__ _|____|___ главата ___|____|____ ___|____|_ си тук!! |____|____|__ _|____|____|____|____|____|____ ___|____|____|____|____|____|__ Адрес на коментара Сподели в други сайтове More sharing options...
NetworkPro Отговорено 8 Януари, 2024 Автор Доклад Сподели Отговорено 8 Януари, 2024 (Редактирано) Рисърчнах малко намерих OMCI протокол с който Huawei енфорсват конфигурацийки (без да питат, баси). Редактирано 8 Януари, 2024 от NetworkPro - Адрес на коментара Сподели в други сайтове More sharing options...
NetworkPro Отговорено 8 Януари, 2024 Автор Доклад Сподели Отговорено 8 Януари, 2024 172.16.0.101 кой тва да си признае? Terminal:CLI(172.16.0.101),Result:Fail,Type:Login,Username: Terminal:CLI(172.16.0.101),Result:Fail,Type:Login,Username: Terminal:CLI(172.16.0.101),Result:Success,Type:Login,Username:root erminal:CLI(172.16.0.101),UserName:root,Result:Success,Cmd:su erminal:CLI(172.16.0.101),UserName:root,Result:Success,Cmd:su erminal:CLI(172.16.0.101),UserName:root,Result:Success,Cmd:su erminal:CLI(172.16.0.101),UserName:root,Result:Success,Cmd:set timeout 60 Terminal:CLI(172.16.0.101),UserName:root,Result:Success,Type:Set,X_HW_DEBUG.AMP.LedTest:,Optype:on Terminal:CLI(172.16.0.101),UserName:root,Result:Success,Type:Set,InternetGatewayDevice.LANDevice:1,X_HW_WlanEnable:1,X_HW_WlanAction:0 Terminal:CLI(172.16.0.101),UserName:root,Result:Success,Type:Set,X_HW_DEBUG.AMP.LedTest:,Optype:recovery Terminal:CLI(172.16.0.101),Result:Success,Type:Logout,Username:root Terminal:CLI(172.16.0.101),Result:Fail,Type:Login,Username: Terminal:CLI(172.16.0.101),Result:Success,Type:Login,Username:root erminal:CLI(172.16.0.101),UserName:root,Result:Success,Cmd:su erminal:CLI(172.16.0.101),UserName:root,Result:Success,Cmd:set timeout 50 Terminal:CLI(172.16.0.101),Result:Fail,Type:Login,Username: Terminal:CLI(172.16.0.101),Result:Success,Type:Login,Username:root erminal:CLI(172.16.0.101),UserName:root,Result:Success,Cmd:su erminal:CLI(172.16.0.101),UserName:root,Result:Success,Cmd:shell erminal:CLI(172.16.0.101),UserName:root,Result:Success,Cmd:exit mID:104509,AlarmLevel:Error,Software upgrading.Terminal:CLI Terminal:CLI(172.16.0.101),UserName:root,Result:Success,Type:Set,SMP.SWM.LoadPack:,ChannelName:tftp,IpAddr:172.16.0.101,RemoteFilePath:... mID:104510,AlarmLevel:Error,Software successfully upgraded. Source version: V500R020C10SPC202B310. Target version: .Terminal:CLI Terminal:CLI(172.16.0.101),UserName:root,Result:Success,Type:Set,InternetGatewayDevice.LANDevice:1,X_HW_WlanEnable:1,X_HW_WlanAction:0 erminal:CLI(172.16.0.101),UserName:root,Result:Success,Cmd:shell erminal:CLI(172.16.0.101),UserName:root,Result:Success,Cmd:exit Terminal:CLI(172.16.0.101),UserName:root,Result:Success,Type:Set,X_HW_DEBUG.AMP.LedTest:,Optype:on Terminal:CLI(172.16.0.101),UserName:root,Result:Success,Type:Set,X_HW_DEBUG.AMP.LedTest:,Optype:on Terminal:CLI(172.16.0.101),UserName:root,Result:Success,Type:Set,InternetGatewayDevice.LANDevice:1,X_HW_WlanEnable:1,X_HW_WlanAction:0 mID:104001,AlarmLevel:Error,Device reset. Cause: System reset after being powered on, Terminal:OTHER Terminal:VoiceServer(-),Result:Success,Type:Set,Services.VoiceService.X_HW_DialSN:,IsHaveAuthed:1 mID:303501,AlarmLevel:Error,OLT started to issue XML configurations mID:404524,AlarmLevel:Error,WAN configuration changes the ACS URL: http://10.20.254.34:37168/basic.xml, Result:Success - Адрес на коментара Сподели в други сайтове More sharing options...
